Der Anfang ist gemacht
Beitragvon Ententanz » Do 28. Dez 2017, 12:30
Ich habe ja alle meine "Na ja, geht so Reps" mittlerweile verkauft und neu angefangen.
Hier mal der Zwischenstand:
Von links nach rechts:
Explorer II 42mm 216570 1:1 Noob Best Edition White Dial A3187 (Correct Hand Stack)
Size 42mm x 13mm (Same as genuine)
Movement Custom designed Asian movement to match the genuine Rolex Cal.3187 movement, Right Handstack, self-winding, independent adjustable hour hand which allows you to turn it clockwise or anti-clockwise to adjust hours and date easily, same adjusting as genuine
Functions Hours, minutes, seconds, date and GMT display
Case 1:1 high quality 316F stainless steel, screw-in back and crown, deep and double line engraved rehaut, brighter and more accurate engravings, random serial number engraved at 6:00 of the rehaut. Different random serials
Crystal Scratch-proof sapphire crystal with anti-reflection coated 2.5x cyclops (Swiss standard, double-sided, same as genuine) the cyclops is very clear as genuine.
Dial Superlumed dial and hands in correct blue color.
Bezel Brushed bezel with 24-hour markers, same as genuine
Strap Stainless steel bracelet with perfect SEL, clasp and smooth screws (The Best Rolex Bracelet EVER)
Clasp New style flip-lock clasp (Super high quality)
Water resistance >50 Meters
GMT-Master II 116710 BLNR Black/Blue Ceramic V7 1:1 Noob Best Edition A3186 (Correct Hand Stack)
Size: 40mm x 12.1mm
Movement: Custom designed Asian movement to match the genuine Rolex Cal.3186 movement, Right Handstack, self-winding, independent adjustable hour hand which allows you to turn it clockwise or anti-clockwise to adjust hours and date easily, same adjusting as genuine
Functions: Hours, minutes, seconds, date and GMT display
Case: 1:1 high quality 316F stainless steel, screw-in back and crown, engraved rehaut, running serial number engraved at 6:00 of the rehaut
Crystal: Scratch-proof sapphire crystal with anti-reflection coated 2.5x cyclops (Swiss standard, double-sided, same as genuine)
Dial: Superlumed dial and hands in correct color
Bezel: Bi-directional rotating real Black/Blue dual color ceramic bezel with silver 24-hr markers
Strap: Stainless steel bracelet with smooth screws (The Best Rolex Bracelet so far)
Clasp: New style flip-lock clasp (Super high quality)
Water resistance: >50 Meters
Sea-Dweller DEEPSEA 116660 "D-BLUE" V7 1:1 Noob Best Edition SA3135
V7 Updated:
1. More accurate platinum coating on the bezel font
2. More accurate brighter rehaut with more accurate engravings
3. Rounded sapphire crystal edge
4. New dials with the long ‘ft’
5. An updated bracelet with black ceramic spring balls
6. Updated new Polished buckle
Size 44mm x 18mm
Movement Asian Super Clone 3135 Automatic Movement at 28800 vph
Functions Hours, minutes, seconds and date display
Case 1:1 high quality 316F stainless steel, screw-in back and crown, deep and accurate engraved rehaut, random serial number engraved at 6:00 of the rehaut, different random serials on different cases. Functional escape valve.
Crystal Super Thick Scratch-proof sapphire crystal with semi-invisible crown etched at 6:00 position of the crystal (same as genuine and this is the first of its kind, one revolutionary breakthrough of the Rolex replicas)
Bezel Uni-directional rotating black ceramic bezel with correct font and updated depth platinum bezel markers same as genuine
Strap Stainless steel bracelet with perfect SEL, clasp and divers extension and smooth screws
Clasp New style glidelock clasp with polished crown logo (The Best Clasp); Polished inner clasp and black ceramic spring balls same as the latest genuine genuine version.
Explorer II 42mm 216570 1:1 Noob Best Edition Black Dial A3187 (Correct Hand Stack)
Die nächsten 2 sind noch im Zulauf, aber beide schon durch den Zoll :D
Werde ich aber wohl erst nächste Woche bekommen :cry:
Sea-Dweller 2017 Baselworld 126600 ARF 1:1 Best Edition 904L SS Case and Bracelet A2824
Size 43mm x 15mm (same as genuine)
Movement Asian 2824 automatic movement; 28,800 VPH
Case Solid 904L stainless steel case, the same material as genuine Rolex watch.
Crystal Scratch-proof sapphire crystal with semi-invisible crown etched at 6:00 position of the crystal (same as genuine and this is the first of its kind, one revolutionary breakthrough of the Rolex replicas)
Dial Superlumed black dial and hands in correct blue color
Bezel Super quality uni-directional rotating black ceramic bezel, correct silver color, font and updated depth bezel markers same as genuine
Strap Solid 904L stainless steel bracelet with perfect SEL, clasp and extension and smooth screws (The Best Rolex Bracelet EVER)
Clasp New style Glidelock clasp with polished Rollie crown logo (The Best Clasp). Polished inner clasp and black ceramic spring balls same as genuine rolex version.
Submariner 116610 LN Black Ceramic V7 1:1 Noob Best Edition SA3135
V7 Updated:
Size 40.5mm x 13mm
Case 1:1 high quality 316F stainless steel, screw-in back and crown, deep and double line engraved rehaut, smoother bezel engraving background, brighter and more accurate engravings, random serial number engraved at 6:00 of the rehaut. Different random serials
Crystal Rounded edge scratch-proof sapphire crystal with anti-reflection coated 2.5x cyclops (Swiss standard, double-sided, same as genuine)
Dial Superlumed dial and hands in correct blue color, reprinted with long ft same as the latest genuine submariner version.
Clasp New style flip-lock clasp with polished crown logo (The Best Clasp). Polished inner clasp and black ceramic spring balls same as the latest genuine Submariner version.
Eigentlich hätte ich ja auch noch gerne eine Submariner "Hulk", aber im Moment bekommen unsere chinesischen Freunde einfach noch nicht die
richtige Farbe der Lünette hin :( Mal schauen, ob sich da noch etwas tut.
Ententanz
Re: Der Anfang ist gemacht
Beitragvon Tresor » Fr 29. Dez 2017, 15:56
Datum bei der Sea Dweller Baselworld sieht seltsam aus.
Tresor
Beitragvon Ententanz » Do 4. Jan 2018, 18:14
Stimmt ! Aber das wahr anscheinend ein "Vorserien-Modell" , die Position und die "Acht" ist Mist. :D Die Uhr auf diesen QC-Bildern hatte ich auch abgelehnt und dann noch einmal neue QCs bekommen. Da war es für mich dann OK.
Habe meine SeaDweller mittlerweile erhalten.
Werde mich dann mal die Tage wieder "Aufraffen" und ein Foto mit dem "Update-Datewheel" hier einstellen.
Nur ich und Fotos, ist immer so ein Sache :shock:
Ententanz
Beitragvon Tresor » Sa 6. Jan 2018, 04:14
Die '8' geht eigentlich noch, sieht nur so als ob sie mittig steht und die '1' davor gequetscht wurde.
Komisch, dass die bei sonst ziemlich perfekten Uhren solche Schnitzer machen.
Tresor
Beitragvon Ententanz » Di 9. Jan 2018, 11:04
Dann darfst Du Dir die ARF DeepSea D-blue aber noch nicht anschauen :D
Die Rehaut-Gravur geht im Moment noch gar nicht, völlig aus der Achse, die Krone steht auf der "59" :oops:
Ententanz
Beitragvon Tresor » Mi 10. Jan 2018, 13:29
Ententanz hat geschrieben:Dann darfst Du Dir die ARF DeepSea D-blue aber noch nicht anschauen :D
Die 'Gravuren' bei den Fakes sehen mir insgesamt immer schwer nach Laser aus.
Denke, dass z. B. die Rehautgravur bei RLX Gen tatsächlich herkömmlich eingraviert wird, aber das kriegen
die Faker wohl noch nicht hin.
Tresor
Beitragvon Ententanz » Do 11. Jan 2018, 11:43
Ich bekomme es besser nicht hin :oops:
Aber alle Datumszahlen sind bei dem "Update-Datewheel" wirklich schön mittig, da wirkt nichts mehr gequetscht.
Ententanz
Beitragvon Ententanz » Do 11. Jan 2018, 21:50
Die von meinen NooBs sind für mich einfach nur gut gelungen. Die haben alle die neue "double line" Gravur.
(Ausgenommen der GMT II, die hat die Einfache)
Aber das zu fotografieren bekomme ich im Leben nicht hin :oops:
Ententanz
Beitragvon Tresor » Mo 15. Jan 2018, 16:31
Geht nicht mit smartphone...
Die Gravur im Rehaut bei Gen ist aber auch wesentlich dezenter als bei Rep.
Jedenfalls meine subjektive Einschätzung.
Tresor
Zurück zu Zeigt her eure Sammlung
Mitglieder: Google [Bot]
